How can I clean the glass from the outside/backside of the window when there is a flyscreen/net in front of it? Is there any solution or tool that can help remove the dust and clean the glass without removing the net?
Hello @Docnhabib
Thank you for sharing your question about your flyscreen. I suggest looking closely at the flyscreen assembly and see if it is held in place with an aluminium panel and screws. If it is, I suggest removing the screws to remove the flyscreen which will allow you to clean your window. Another possible method is to try and lift the flyscreen to see if it will come off the rails. Sometimes the flyscreen is just placed in one of the rails of the window assembly. By lifting it up you can then pull the bottom out and off the top rail.
Please remember to wear personal protection such as gloves, goggles and a mask. Please take photos of the flyscreen assembly so that you remember how you got it out.
Dumb as I am, I don't understand why a security/fly screen would be 'secured' in front of the glass?
Hi @Docnhabib,
I'd also recommend checking if the window itself can be removed. Oftentimes sliding windows can be removed by lifting them up, tilting the bottom outwards so the bottom of the window clears the frame, and then lowering the top of the window out of the frame.
With the window out, you'll be able to clean it as you would any other window, simply reversing the process to reinstall it after cleaning.
Let us know how you go.
