Hi folks'
Currently removing mortar from bricks but some of the mortar takes an extremely long time to remove with mallett and chisel. Is there an alternative way to remove mortar?
Cheers,
T.
Hello @TJP
Thanks for sharing your question about removing mortar from bricks. You could try using a demolition hammer on low setting, but there is a high probability that it could split the brick even on low setting. My best advice is to build a timber holding jig for the brick so that it stays in place while you are using your mallet and chisel. This leaves both your hands free, and you can get into the best position possible while using your tools.
Let me call on our experienced members @Dave-1, @TedBear, @JoeAzza, @DIY4Knuckleheds and @Nailbag for their recommendations.
Please remember to wear personal protection such as gloves and goggles when working on your project.
Hi @TJP
You could use an angle grinder with a masonry grinding wheel but it will produce a lot of dust. So you will need a decent set of full face ppe.
But can I ask why and how much you need to remove? It would help to advise more appropriately.
Nailbag
Evening @TJP
You are doing it the only way I know how to :) Practice and it becomes easier and following "sheer lines" makes life a lot easier. By sheer lines I mean having the chisel against the brick and following along the edge of the brick (you are probably doing that but mentioning it just in case) I have removed a lot of mortar and broken up rocks and concrete, somehow when you pick whatever it is up and look at it you can see the most likely point to place the cold chisel and also which direction to have the force.
Good luck, its worth it :)
Hi @TJP , I have cleaned old solid bricks with mortar using a small axe, it worked well and quick, just make sure you wear PPE, safety goggles , leather gloves.
Hold the back top end of the brick upright on an angle, using the axe in a downward chopping action to chip away the old mortar.
Hi everyone,
Thank you for your replies.
@Nailbag I've knocked down an old wall and am resuing the bricks for the new wall. There's approx 40 or so bricks to-do.
This is what they look like.
Again producing a lot of dust but these honing discs are ultra efficient. You will be able to get the mortar off easily and maintain their original surface.
Hi @Nailbag
Much appreciated brother.
Thank you,
