Hello,
I’m planning to install a floating TV unit in my nook. However, the wall studs don’t align with the mounting point of the suspension rails.
I am considering installing a timber ledger across the wall studs and then attaching the suspension rails to the timber.
The total width is 3m (1 x 180cm tv unit and 2x 60cm )
What type of timber and size would be best to support the units?
Should I use 19mm DAR Pine or 35mm mgp10 untreated pine? Or would you recommend something else?
Please see the image for the stud locations inside my nook for reference.
Any advice or recommendations would be greatly appreciated!
Thank you so much!
