I am looking to replace a fence post as the base is all worn out. I can find the steel post in bunnings, but, anyone know where I can get the steel bracket? Trying to avoid to remove the entire post and transfer the bracket as I have a feeling the entire fence is going to fall down
Hello @Pete112
Thanks for sharing your question about your fence post bracket. I'm sorry but the store does not carry the 50x50x100 fence bracket. The closest item we have is the https://www.bunnings.com.au/carinya-50-x-100-x-50-x-50-x-4mm-galvanised-reinforcing-z-bracket_p3961583 . I suggest placing temporary support timber pieces to the fence rail and the other side of the fence in order for you to remove the angle bracket and the metal post.
Once you see the extent of the rust damage, you'll have a better idea if the bracket can be recycled or not. You'll also be able to assess how bad the damage is to the post. My best advice is to make sure that the replacement piece that you get is fully galvanized and is similar in size to the one you currently have.
Let me call on our experienced members @Dave-1, @Nailbag, @DIY4Knuckleheds and @ @Neil1984 for their recommendations.
Good Evening @Pete112
I would go the route of installing two new posts around 2feet from the old post either side, No need for brackets just drill straight through the post and the rails and use a bolt to attach them all together. I wouldnt try that solution on the existing join as the lapping of the rails looks like they will fail sometime soonish. You could try, and if you do I would suggest a piece of hardwood (merbau) to span across the join, kind of like a large rectangular timber washer. Then a bolt through the washer, rails and metal post.
Hi @Pete112
If the photos of the slit rail is an indication of the condition of the timbers of the fence, I would say replacement maybe a better direction of time and money. How are the posts are they loose and is the fence leaning or can it be waved by hand? If yes to these are the answer then replacement would be the smarter investment over repair. Especially if this is your long term home.
Nailbag
Sorry, I should have explained the issue in more details. The fence is leaning as the post is rusted out.
Knowing this now, would you recommend one of those post support or whether I should install 2x extra post to provide more support? The other option I am thinking is to install another post directly connected to provide support as that will only require me to only have one post. Thoughts?
Trying to avoid a full fence replacement as it's costly
Hi @Pete112,
I'd recommend going with two posts rather than trying to attach everything to a single post. This would provide a much simpler and more secure connection for your fence rails. The main reason for this choice is that you will need to account for the concrete at the base of the existing post. By installing a post around 600mm on either side of the existing one, you should avoid the concrete at the base and support the fence even better than it was originally.
There's no real need for the brackets. You can simply position the posts, drill pilot holes through the posts and secure the rails using suitably sized exterior-rated timber screws. Just make sure the screws are long enough to achieve a solid fixing into the rails without protruding through the other side.
Just outta curiosity more than anything - because I haven't seen these bracketed style posts before. When they were built, would they have used something like a coach screw from the bracket side to hold the rail firm - or not? If not @Pete112 should be able to tap the top of the post and easily remove it - as there is nothing left at the base.
Theory, of course.
Worth while digging down to see if there really was concrete used in the fence construction?
Afternoon @Pete112
Id go back to option 1 and use two posts either side, it will help support the fence a little longer. But I would start a money box to get get ready for replacement time as well :)
The post is technically holding on by a bit of metal. I don't think there is concrete under it. Leaning towards 2x post now. Can anyone recommend me which concrete to buy and tips on doing this? I've never done this before and quite new to it all
I suggest having a look at this guide - How to Set a Post. It will show you what you need to do when setting a post. I recommend looking at using the https://www.bunnings.com.au/bastion-20kg-concrete-mix_p0038287 for your post footing. My best advice is to make sure to use a spirit level so that the post is square and level.
