I have a Bosch washer: WAW28460AU/24
I'm fairly certain it wasn't leaking before I disconnected and connected it a few times. Prior to this it had been sitting connected for 4.5 years with seemingly no problems.
I cannot confirm that there isn't an invisible hairline crack.
I took the washer out, cleaned it for the hell of it (looked ok though).
I even cleaned the build up on the tap with vinegar.
It could be that it was too tight, and now just won't seal again. ChatGPT isn't being very helpful.
The Bosch replacement inlet hose + Aqua Secure is $73.54. The rubber washer and plastic filter (aka "Sealing with sieve for Aqua-stop-valve") are $37.70. Both would require $10 shipping. This seems ridiculous to me.
I would like to replace the washer to see if that fixes the problem, but I am having trouble finding a suitable replacement.
A bit of rubber can't be that hard to find and can't be that expensive - surely? Surely other people have tried to do this for less than $50!
ChatGPT tells me that if the washer was compressed too much, and for too long, that it simply may not be doing its job any more. Another thing I cannot properly assess. I don't know how firm the rubber was when it was new.
Given that over-tightening might be the original problem, I am reluctant to tighten it some more.
Okay looking at the first photo I took, the washer didn't really look okay, and that is why I removed it to try to clean it.
Does anybody know why there is that black bit with the white nut? Is that where there may be an invisible crack from over-tightening?
