A low brick retaining wall that we inherited on a property we bought has started to break off at the corners and is leaning forward. There does appear to be some holes for draining, so it is not clear if the tilt is due to the tree roots from the trees behind (see pics) or just water build up. Grateful for your advice on what can be done to prop up the wall (or at least prevent further tilting) to avoid having to do major works.
Hello @EXF
Thank you for sharing your photo. Looking at the retaining wall, I can see that the corner has deteriorated, with sections of brickwork and mortar breaking away. You've also mentioned that the wall is leaning forward, which suggests there may be pressure building up behind it.
There are a couple of possible causes. Tree roots could be contributing to the movement, particularly given how close the trees are to the wall. Another possibility is water accumulating in the soil behind it. Although you've noticed drainage holes, these can become blocked with soil and debris over time, allowing water pressure to build up.
If you're hoping to avoid major reconstruction, I suggest starting by checking whether the existing drainage holes are clear and whether water is collecting behind the wall after heavy rain. You could also monitor the movement by taking measurements of the lean and photographs from the same position every few weeks.
It's possible to reinforce some retaining walls using additional posts or engineered supports along the front. However, these need to be properly designed and anchored to withstand the pressure of the retained soil. I wouldn't recommend simply installing timber posts or steel stakes against the wall, as they may not provide sufficient support. The leaning brick wall might simply lean around the support post and come apart.
Before undertaking any repairs, I'd recommend having a structural engineer or experienced retaining wall specialist inspect it. They can assess whether tree roots, drainage or inadequate foundations are responsible and determine whether the existing wall can be stabilised without completely rebuilding it. Given the visible deterioration, I'd avoid disturbing the soil or cutting any nearby tree roots until the wall has been assessed.
One encouraging aspect is that the wall appears relatively low, so there may be opportunities for a more economical repair. However, the amount of movement and the condition of the foundations will ultimately determine what's practical.
In the meantime, I suggest keeping people away from the leaning side and avoiding additional loads or digging behind the wall.
Let me call on our experienced members @Dave-1, @Nailbag, @TedBear, @JoeAzza and @DIY4Knuckleheds for their recommendations.
Hi @EXF, that corner is a natural weak point. So much pressure behind it and so little support, since the corner walls are not properly tied together, such that they are effectively just two separate wall ends. The tree roots are very likely contributing to the forces pushing it all over. I have recently assisted a friend with a similar situation. (In that case it was just one strong tree root that had grown thicker next to the wall and pushed it over.)
I'd suggest digging out a trench (300 - 400mm wide} behind the wall and removing any large roots that may be present. Then build a brick or concrete column inside the corners. (It doesn't have to look neat, just strong. It will be buried.) You'll then need to lever the wall back into an upright position and pack dirt or stones back into the footings.
You may need to build some more columns beind the wall to keep it upright.
Then add some large chunks of rubble into the trench to divert some of the sideaways forces from the dirt from pushing against the wall. Large rocks help to take some of the load. Then you can backfill the trench, adding rubble until you're near the top.
Hi @EXF
I would follow @TedBear advice in removing the soil and any tree roots directly behind the wall. I would also remove the tree in front. This is going to be required to build a replacement wall as I’m doubtful that you will get able to lever the wall back without it cracking and breaking apart at the mortar courses.
It will take some work to clean them up, but you should be able to salvage the bricks and have the wall rebuilt.
Nailbag
Good Evening @EXF
I have always looked at leaning retaining walls and tried to figure out how I would repair them without replacing them. For the same reasons that @TedBear and @Nailbag have outlined I have never really found something that will have a high degree of success.
The steps I have come up with are pretty much what has been mentioned.
So all the above is not lost if it fails as you would have to remove the wall to redo it in the worst case. There are numerous ways to redo the wall :) I prefer gabions as they allow free drainage and also do not need a footing plus you can use the old bricks in the gabion baskets. Roots will not grow into the baskets either. (Search for gabion walls and you will see a bunch of them)
Looking forward to how you go :)
Thank you all so much for taking the time to respond - this is most helpful. The steps all make logical sense. This seems like a way bigger project than anticipated so it may be some time if/when I provide any updates. I am sure there will be others that will also benefit from the thoughtful advice provided above!
With gratitude,
EXF
Hi @EXF,
I'm glad you've found the advice helpful.
Just a final word of caution. If you're at all unsure about tackling this project, I'd strongly recommend enlisting the services of a professional, particularly for removing the section of wall that's shifted.
Even a relatively small section of brick retaining wall can weigh several hundred kilograms, and attempting to lever it back into position could cause it to collapse unexpectedly. It's simply not worth risking serious injury to yourself or others.
My recommendation would be to have a professional safely dismantle at least the affected section and assess the remaining structure. You could then potentially tackle rebuilding it yourself once the foundations and drainage requirements have been established.
Please keep us updated if you do decide to proceed.
Thanks @MitchellMc - yes it is definitely sounding more like a job for experienced hands. I am so glad there is a resource like this community to get advice - and so responsive too!
