What alternatives do Bunnings have for micro cement look/feel for a kitchen bench top.
Currently laminate however want to modernise.
Hi @Jcroberts001,
Unfortunately, I'm not aware of a microcement product suitable for resurfacing kitchen benchtops.
If you're looking to achieve a similar modern appearance, I'd suggest considering a stone-look benchtop available through our Special Orders team. There are a variety of finishes that could give you the contemporary look you're after.
Are you specifically looking to resurface your existing benchtop, or would replacing it be an option?
Looking at resurfacing the existing benchtop due to $$$.
Would something like a thin cement coat? Venetian plaster type work? Sealed to be waterproof etc.
The main challenge is that laminate is an extremely smooth, non-porous surface, so there aren't many products that will bond reliably to it.
Unfortunately, cement-based coatings and Venetian plaster aren't designed to adhere directly to laminate. Even with extensive preparation and a suitable primer, there would be concerns about adhesion, cracking and long-term durability, particularly on a kitchen benchtop that's exposed to water, heat and regular cleaning.
Of the products I'm aware of, your best option for resurfacing laminate would be a specialised coating such as the Dulux Renovation Range. This is designed for surfaces like laminate and can provide a durable finish when the correct preparation and application process is followed.
Although it won't give you the texture of microcement, you could choose a concrete-inspired grey colour to achieve a similar modern appearance.
I'd be hesitant to recommend applying a thin cement coating and sealing it, as even a waterproof sealer won't overcome potential adhesion issues with the laminate underneath.
Here's a helpful step-by-step guide: How to paint a kitchen benchtop with Dulux.
Let me tag @TedBear, @diy_hausdesigns and @DIYGnome to see if they have any thoughts.
Hi @Jcroberts001, having changed worktops in a number of houses I've owned, I can't see that attempting to put a coating on the existing laminate will actually be a money saving idea. If it breaks off, (as I'm betting it will, sorry) it will cost you more in the long run than if you'd removed it and replaced the top with what you actually want. If you really want to cover it, I'd suggest using tongue and groove timber to make a new work surface. It will take the knocks and protect the surface underneath. If you want the concrete look, remove the existing surface and have the top made that you want.
I find in life, that you eventually forget the money spent or "saved" and only remember the outcome, either good and bad.
