Hi everyone,
I am looking for advice on two issues with my corrugated metal roof.
1. Lifted Ridge CappingAs shown in the close-up photo, the metal ridge capping has lifted and bent upwards, creating significant open gaps between the capping and the roof sheets below. The capping is no longer sitting flush against the ribs of the metal sheets, leaving the roof cavity vulnerable. The wider shot shows the overall roof structure.
- What type and size of roofing screws should I use to properly anchor the capping?
- Should I install foam ridge infill strips, roofing silicone, or flashing tape?
2. Stubborn Roof GrowthI also need advice on the best practice to clean the crusty white and grey growth (which looks like lichen) off the roof panels just above the gutters, as shown in the last photo. I tried to manually scrape it off with a hard tool, but it is extremely sticky and takes far too much time and effort to remove by hand.
- What specific cleaning solutions or treatments from Bunnings are best to dissolve or remove this easily without damaging the metal roof?
- Should I be looking at a "spray and leave" chemical treatment, or is there a faster recommended method?
Thanks in advance for your help!
