I am planning to pour a small slab which will sit in a pocket around existing house slab. Do I need to use expansion joint form for this? Slab size will be 2.7x1.2x0.1 meter, tiled finish.
Thanks
Hello @jinuaus
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about building a concrete slab.
First, I suggest having a look at this guide - How to pour a concrete slab by @tom_builds. It's an excellent guide and shows you the basics of making your own cement slab. Expansion joints are recommended wherever new concrete meets an existing slab or fixed structure, such as a house foundation, brick wall, driveway, retaining wall, post or drainage pit. They allow the concrete to expand and contract with temperature changes without placing pressure on surrounding structures. For longer concrete sections, additional movement joints may be required, depending on the slab size and design. I suggest using a suitable compressible expansion joint filler such as Ableflex to separate the surfaces. Please remember to check the size and lenght you'll need for your project.
Let me call on our experienced members @Dave-1, @Nailbag, @TedBear, @JoeAzza and @DIY4Knuckleheds for their recommendations.
Please remember to wear personal protection such as gloves, goggles and a mask.
Good Evening @jinuaus
Now I am a bad concreting person :) (I just concreted the end of some paver runs and used quickset concrete as it had all the bits, long story but its rough)
I would still use expansion foam between a new slab and and existing slab, to be safe as they will expand differently (one will be in the sun, one is under the house) No point in going to the expense and hard work for cracks to develop is the way I would be thinking.
And yeah found out/worked out afterwards about what type of cement and base I should have used :)
Thanks @EricL and @Dave-1.
my plan is to dig 150mm deep, fill 50mm with crushers dust and compact , place builders plastic over it, place reo mesh and concrete with 20mpa. As Dave mentioned, I can add expansion form on the sides touching the house foundation. In this case how would I tile properly? Is tiling over expansion form good practice?
Jinu
When tiling over an outdoor concrete slab with an expansion joint, I suggest making sure the joint continues through to the tiled surface. This allows the concrete to expand and contract with temperature changes without causing the tiles or grout to crack.
The first step is to plan your tile layout so that a tile joint lines up directly above the existing concrete expansion joint. Avoid laying a full tile across the gap, as movement underneath could eventually cause it to crack or lift.
Next, lay your tiles on either side of the joint using a flexible tile adhesive suitable for outdoor use. Make sure the expansion joint remains clear of adhesive and grout, and leave a suitable gap between the tiles to accommodate movement.
Once the adhesive has cured, clean out the joint and insert a suitable foam backing rod, such as the Moroday Gap Filler Rod https://www.bunnings.com.au/moroday-10mm-x-5m-white-gap-filler-rod_p4061881 available at the store. Choose a rod slightly wider than the gap so it fits snugly and helps control the sealant depth.
Finally, fill the joint with a flexible, exterior-rated movement-joint sealant suitable for tiled surfaces, UV exposure and the expected movement such as the https://www.bunnings.com.au/sika-300ml-white-sikaflex-11fc-purform_p0628965 . You can use painter's tape along the tile edges to achieve a neat finish, then smooth the sealant and remove the tape before it skins over.
Please remember to wear personal protection such as gloves and goggles.
