Just needing some assistance with how to get started with the prep and painting of our home exterior. She isn’t in the best condition. What do I need to use to prep it before the paint?
Hi @projectmumdanni,
Preparation is the most important part of any painting project, so taking the time to prepare your surfaces thoroughly will make a huge difference to the quality and longevity of the finish.
With the old paint flaking as it is, ideally, you'd want to remove it all before repainting.
One important consideration is the age of the house. If the existing paint could contain lead, particularly on a pre-1970 home, have it tested before scraping or sanding. Lead paint requires specific safety precautions and if it is present, you would be best to contact a professional for their assistance.
If it is ok to proceed, start by giving the timber a thorough clean with sugar soap to remove dirt, grease and other contaminants. Once dry, use a paint scraper to remove the flaking paint, then sand the timber back to a smooth, sound surface. You don't necessarily need to remove all of the old paint, however given the spiderweb like cracking throughout, I'd say you need to remove a fair bit. If any paint is left over, make sure to sand the edges to remove the sharpness as deviations in height will show through the layers.
Once sanded, remove the dust and fill any cracks, holes or imperfections with an exterior timber filler. Allow it to dry, then sand it smooth.
Next, use painter's tape and drop sheets to protect any areas you don't want painted. Apply a suitable exterior timber primer such as https://www.bunnings.com.au/dulux-4l-1step-prep-primer-sealer-undercoat_p1370234 , followed by two coats of a quality exterior paint such as Dulux Weathershield, allowing the recommended drying time between coats.
I'd recommend checking out How to paint weatherboards and How to paint your house's exterior for further guidance.
You might also like to check out DIY exterior house paint and restoration by @amber227 and Weatherboard home renewed with paint by @Dinny. Both are fantastic examples of what can be achieved with thorough preparation and a fresh coat of paint.
Let me know if you have any questions.
