Looking for some DIY advice on reinforcing my patio gutter.
The previous owner has attached the gutter directly to the patio roof sheets with no structural support behind it and the gutter is now bowing outwards and overflowing.
I'm wanting to extend approximately 320mm out from the existing steel patio frame to create solid fixing points for gutter supports.
Ideally, I'd like to use U-bolts or clamps if possible to avoid drilling into the existing frame or welding.
Has anyone done something similar or have suggestions for suitable brackets, materials or a better way to do this?
Also, is it worth trying to reinforce the existing gutter or am I likely to continue to have issues at the weak spot of the current gutter down the track and better off replacing the gutter?
Thank you!
