Hi team,
I'm in the process of ripping up the carpet in preparation for someone to come in to install hybrid flooring. There looks like some water staining/damage on the plywood but the moisture levels in the building inspection report came back normal around the bathroom area.
My question is whether I should cut out the stained plywood and replace it before we start the hybrid installation? And would it come out easily? The corner is slightly lifted but this is old and we've been told we could just add some screws in again. It's soft but not spongey so I'm thinking of stabbing a screwdriver in to see if it goes through- just to see how bad it is.
Also, the ledge just before the doorway into the bathroom (where the tiles are) is disintegrating. What should I ask for when I go into Bunnings so that I can replace it?
Thank you so much for your help in advance!!!
