I want to paint over interior walls that are currently very dark grey. I want to paint them white to make the rooms fresher. What preparation should I do to make sure I end up with a good result?
Ta,
Cath
Hi @CathD, good question. I wondered the same thing when I recently started repainting my new house white - I chose Dulux Lexicon Quarter. I had to cover some darkish walls, a very vibrant green and I have 1 darkish blue wall to go.
I'm no expert, and I think my answer will prove that, however this is what I did and it's worked perfectly. I simply lightly sanded and cleaned the walls and started painting - nothing secret here. Then I did as many coats as necessary til the walls were white enough. The most coats I've had to do so far was on the vibrant green wall - 5 coats.
So please, if someone has a special trick - please share 🙂
I guess the most important thing is that you use quality paint (Dulux) and rollers (Monarch Razorback are great). Also just have a chat to the paint peeps at Bunnings (or Dulux direct) and let them know what you're doing because the tint in some whites can make the job a little easier.
There are now paint products on the market that are specifically for covering dark walls. I would speak to a specialist at your local paint store before wasting days with multiple coats! Dulux definitely do one called Wash&Wear + Super Hide.
