I'm renting a flat above a shop (first floor) and am having an issue with a blocked drain. If I can fix the problem without having to get a plumber in then I would prefer that.
So we had lots of issues at least ten years ago with the same shower drain. But we had a plumber come and fix the problem and we haven't had any issues since. At the time the plumber said that the pipes coming from the kitchen sink were installed badly and cheaply and would likely be a problem in the future.
The shower drain that now has standing water in it has never been used as a shower in the 15 years that I've been living here. And it hasn't even had any water in it for at least five years. We have another bathroom that is on a separate system that we use instead. I mention this so you know that is not likely to be a hair blockage in the shower drain but actually a blockage somewhere else that is causing water to back up and flow out from the lowest drain point which is our unused shower drain in the laundry.
My housemate thought that the sink in the laundry was draining slowly and/or flowing back in to the second sink. So he poured a small amount of Drain-o as per the instructions into both sinks. While the sinks seem to be draining better we now have this issue with the shower drain backing up and having about 2 inches of foul smelling drain water in the bottom of the unused shower. My housemate used the Drain-o on Saturday evening and the shower drain began spewing water on Sunday afternoon. I've never heard of Drain-o causing a blockage. Is it possible? And how do I fix it? We have tried using a plunger but that just brought up gross stuff from the drain and didn't fix the problem. We have also used a wire hanger in the drain pipe but didn't have much luck there either. Please help.
If you have any suggestions I would be forever grateful.
Thanks
