As a bit of background, we don't have any air-conditioning in our current house, but as its an old house (+80 years old) has high ceilings, in summer the house gets very hot, no insulated sarking under roof tin, however there is insulation in the roof space although it looks like its been done poorly and needs replacing. I've been holding back until I renovate the remaining rooms as all the old lath and plaster on ceilings and walls will all be removed.
So over the weekend I finally got around to installing a couple of whirlybirds on the roof to vent the ceiling space and hopefully make things a bit more comfortable or at least bearable this summer (also put one in the shed)
Installation was all straight forward and now I also want to install some adjustable ceiling vents in some rooms to help vent the hot air in summer and that I can close in winter. e.g. bedrooms and living areas. These will vent into the ceiling space, where the whirly birds will be pulling the air through.
Is there any particular location on the ceiling they should go, i.e. close to the outside wall / windows or should it be close to an internal wall, or just in the middle of the room? As mentioned the old ceilings will be pulled down so is only temporary (at least for a couple of years anyway)
cheers,
Stephen
