These days, we have so much to choose from as far as timber goes.
Back in the day, it used to be merely MDF board, which was OK, unless it got wet and it would swell up and twist and ruin anything
you made out of it.
Moving forward a number of years, we now have plywood, it is kiln-dried, you can get it in any size you like from 8mm up to 19mm
should you need that thickness and in sheet sizes from 1200 x 1200 up to 2400mm x 1200mm.
Do you folks use MDF?, sure it's OK for stuff inside the house, but for a garage/workshop?
What are your thoughts, either way?
Cheers,
Mike T.
