Hi all,
I'm looking to build a cage for my 4 guinea pigs which will be indoor in my room/office.
I just saw that Bunnings are giving away free wood pallets and I was wondering if its okay to use those wood pallets to build a cage for pets (considering my pets are guinea pigs and they might chew on it)? I read online that they were treated for heat, etc.
If wooden pallets are not safe then I guess I'll get everything from Bunnings but can you please give your expert recommendations?
- For the base and the wall, should I use MDF? Or is there a better option
- For the cover on the base, I used a PVC pond liner before to protect the base from pee/leaking water bottle and it was okay. I was wondering if contact paper is a better option?
Regards,
James
