hello all and hopefully thanks in advance. I have a long term problem with the spot where a pvc pipe joins a pool. The builder was very good and we worked together well but he has passed away now after a long illness and I couldn’t bother him or his familyThe pool is fibreglass lined but there seems to have always been a leak where this pipe joins even though the fibreglass seems to have been wrapped around the join. The pool is actually on the first floor so the leak goes thru 200mm of concrete and into a room unfortunately. If it was in the ground it wouldn’t matter.
so, after a few other things failed, the builder fibreglassed over this section but unfortunately I think there was a tiny lip where it joined the tiles and the leak continued, smaller, but still there. (I removed that fibreglass ‘cover’ before taking photo.) I removed the single tile at the right to check whether the fibreglass went under there, which it seems to, or whether it was another layer the builder had put on. I can’t tell where the leak is exactly. Maybe at the couple of chips you can see in the photo (or maybe I made those chips removing the ‘cover’). Maybe where the fibreglass seems a bit thinner at the bottom. It is impossible to tell.
so, how to permanently fix this? I feel fibreglass to the tiles as the builder did has the potential for a lip again. I feel fibreglass should smooth or blend in over the top of the other fibreglass. I could remove another row of tiles without it being very visible
does anyone have any suggestions? Could I do a fibreglass patch myself with zero experience working with fibreglass. If a professional would be better what type of pro is it? Surfboard repairer?
it is not a huge pool, maybe 12,000 litres but at the bottom so maximum pressure for a small pool. Also, the pipe is not necessary for the function or safety of the pool so it is ok to block it off.
sorry such a long post but I thought detail most helpful
thanks
