Hello All,
I have moved into a new place and here is a picture of under the sink in the Laundry. Can you tel what could the blanked out white pipe above the cold water valve be for?
Also, what could the left wide outlet that I have covered with the black plastic wrap be used for?
The valve has mismatched adapter thread size so my washing machine cold inlet tubes do not attach.
Shall I get an adapter to blank the one side of the valve and let the hot water hose left lose ? or shall I get an adapter that fits the valve to upsize and connect the cold supply to the hot water inlet.
PS I have Fisher and Paykel 8.5 washsmart
Sorry for the long post!! Thanks so much in advance !
