How can I stop this from happening?
Bought this last week and I have only used a couple of times. Now the cap is glued shut even though there is plenty left in the tube.
Hi @Cider
I feel your frustration as this has happened to me several times as well. You'll need to use a Craftright 250mm Multigrip Plier, to twist that cap off. I recommend cleaning the screw threads of the tube and putting on some cling wrap before putting the cap back on. The cling wrap acts as a buffer between the cap and the glue. Next time you need to use it, the cap should twist off without effort.
As per Eric.
But I usually put the cap in a wood vice - and go for it.
