I am looking at using the Ekodeck Castellated panel as a fence line in my yard.
https://www.bunnings.com.au/ekodeck-219-x-26mm-3-6m-carbon-batten-screen-castellated-panel_p0488949
All of the installation examples show it mounted against an existing fence, however I need to build the supports for it as it's going across the yard.
I can use metal posts as the posts, but unsure what to use as the battens, so that they are both strong enough and will also last in the elements.
Timber is likely to warp and degrade, and metal top hats which are recommended for wall mounting don't appear to last well when exposed directly to the elements.
Does anyone know what the best system would be for the battens?
