Hello everyone,
My end goal is to remove my rainwater tank. The tank itself looks easy enough and I believe I can manage that on my own so my question does not have anything to do with the tank.
The tricky bit is redirecting the rainwater pipe into the rainwater drain and that is my main question today.
The reason why I am asking this today is because I've had quotes over $450 just to redirect the rainwater pipe and think that it is a bit much for this job (if it's as easy as I think it is).
I have done some research and I think it looks straight forward enough but I wanted to get some more experienced advice and confirmation that I understand it correctly.
MAIN QUESTION:
How do I redirect the rainwater pipe away from the rainwater tank and into the rainwater drain?
Here are the steps I think are needed to redirect the rainwater pipe:
1. Cut off the existing pipe joint leading into the watertank
2. Purchase the required pipes and pipe joint
3. Place the new pipe joint and pipe to direct the water into the drain
4. Glue the pipe joint and pipes using the purple and clear stuff (not sure what they are exactly yet but I have seen them on YouTube videos)
Here are my follow up questions:
Q1. Is there someway to reuse the pipe joints or would I have to cut out the existing ones and purchase new ones?
Q2. If I can reuse the pipe joints, how do I undo them since they are glued together?
Q3. Are my steps correct?
Q4. Is it more complicated than I though and I should get a professional to do this?
Thank you for your assistance.
