Hi Team
I am planning for a new bathroom which will be framed, roofed, floored and wether board cladding by a builder. i choose to finish the internal.
1.I am planning on 6mm villaboard lining on the internal studs for wall. insulate with batts
2. 6mm ceramic tile James hardie underlay on top of particle or plywood subfloor
3. i would double up to raise the entire floor and so i can create a slop in the walk in bathroom by screeding down towards the drain
4 tiling all floor area and walls up to the ceiling
the questions are
1. do i need water proofing. is it on or under the cement board. i could not find a instruction or video to waterproof or not to on a cement board when used as bathroom floor or under tiled shower area
2. is the thickness of the board appropriate for the wall or do i need a some kind of backer board
