Basically aiming for a DIY shower de-and re-instal. Some advice would really be appreciated for this DIY project. Things to watch out for. First I'm planning to rip out the 1980s set up. The visible part of the base, seen from top, is 860 x 860 mm max, side to side, and 820 x 820 from back to front where sliding door is. How that makes for a 900 x 900 base I'm not sure, unless 2 cm or so of the lip are all under the wall coverings. Anyway, the plan is to rip it all out, then get the plumber to get the pipes and exit right for a new solid tray (900 x 900 and high grade acryl or similar walls. 900 x 1200 might also fit easily if linen cupboard is taken away. Descriptions of tray and potential walls are generally not clear enough in terms of quality. I need recommendations, what's good, what's bad. What to watch out for. Not planning to use tiles. A front glass door would be fine, perhaps with a narrow fixed glass panel to keep door width relatively small. What do I watch out for? What do I need? Also what shower fittings might be good quality, with hand-held shower as well as overhead. Neither want old style shower head (truly sick and tired of it) nor exaggerated modern one (what the heck!). Nothing wasteful. I guess tray needs to be set in mortar. Any advice there? Walls are villaboard, I guess, sealed and painted,then lining glued. With what exactly? How to get sizes right? How about edges and corners? What do I use. Would thick paper templates be a good idea? Any advice on those steps, esp. handling of lip and cladding/lining over it. I'm checking everything Bunnings has; not sure that's enough. Very much appreciated, Nick.
