I already have a circle cutting template for cutting circles with a router, however, I needed a template that I don't have to drill a pivoting point, leaving a small hole to be patched up.
I found many ideas on youtube and came up with is one I made. using double sided tape for the pivoting point.
I will be using it to make a circle based planter stand in the near future.
Adjustable sliding pivot point.
Install double sided tape to base of 65mm x 19mm diameter timber circle.
I made a center marking tool from a 5/16 inch screw, ground down to a point to locate the pivot point of the circle
A small shaft used to locate a second 65mm and 19mm circle timber pivot.
Installed a measuring tape (double sided tape) to cut the required circle radius.
