I have an Ozito (2000W 254MM) table saw. Please advise on what kind of dust extractor/collector will be best suited. Is connecting a vacuum a good idea?
Thanks.
Cheers,
Prasoon
Hello @itsme_prasoon
Welcome to the Bunnings Workshop community. Thank you so much for joining us and sharing your question about a suitable dust collector for your Ozito table saw.
Congratulations on getting a new table saw. Nothing feels quite like getting a new tool for the shop and giving it a test run. Getting a dust extractor is one of the best ways to contain sawdust from spreading in your work area. I recommend the Ozito 1250W 20L Stainless Wet And Dry Vacuum, the fittings included are compatible with your table saw. It's a great multi-purpose vacuum cleaner and comes in a 35l size should you want a larger storage bin.
Please keep us updated with your progress. We look forward to seeing your first project from your table saw.
Here is a handy link: How to stay safe during D.I.Y. projects by @Adam_W
Thanks a lot, Eric. It helps.
Gday @itsme_prasoon
Any wet and dry Vac will do, just as long as its got a large enough storage bin. I used to have a small dust extractor and it did an awesome job, plus didnt have to empty the bags as often. I have upgraded to a 2 stage dust extraction unit, as I now have a few big tools in the shed. Its better to have a unit that can do the job easily rather then just able to do the job. Plus it all comes down to your budget and how much space you want it to take up.
From
Razzer
Hi @itsme_prasoon
As suggested any wet and dry vac will do the job, However I would look at a good unit which has a very good capacity as you will use it all over the place. another suggestion is to included a cyclone dust collection which will save you a lot of money in the long run.
Razzer called his system a two stage and at a guess he has a cyclone dust collection. There are heaps of YouTube videos on them and if your keen to build your own here is a video on how to build and all components can be obtained from Bunnings
your choice of vac will be controlled by how much you want to spend. If you don’t want to build it the cyclone collectors you can obtained them from ebay carbatec timbecon etc.
https://www.youtube.com/watch?v=9w8jXS8Fjh8
Related, I have a new version of this model, and it seems they have changed the dust extraction design and it doesn't match the manual any more. The dust extraction port on the back has a splitter with 2 ports;
Dust Extractor Port
At first I thought maybe this was two slightly different sizes for different vacuum connectors, and only attached to the straight-through port. But the dust collection was crap since most of the air was just being sucked in from the right-angle port. So you'd need to block the other port. Then I was wondering if perhaps the idea is you attach the vacuum to the right angle port and a sealed container to the straight port, and it acts as a crude separator with the larger/heavier chunks failing to make the right-angle turn and end up in the sealed container.
But another mystery was the table came with a section of vacuum hose. There is a very slight possibility that this hose actually came with something else I've got and it was just lying around and got muddled in with the table-saw parts when I was unpacking it. However, I don't think so, because another thing I noticed is when you unscrew the black cap from the top of the blade guard, it reveals what looks like another dust extraction port;
Blade Guard Dust Extractor parts?
So I think the completely undocumented correct way to install this is to use the vacuum hose to connect the blade-guard and rear dust collection ports like this;
Correct dust extraction assembly?
So far it appears to be working OK. I can imagine the hose getting in the way for large pieces but I haven't done any of those yet. I'm not sure if this is better or worse than not using the hose and just blocking the other right-angle port.
Hello @dbaarda
Welcome to the Bunnings Workshop community. It's marvellous to have you join us, and thank you for sharing your experience with the new Ozito table saw.
It's an interesting addition to the dust collection system of the table saw. Any sawdust kickback coming from the blade will get caught by the secondary collector. However, if you had a large panel that needed to be cut down that hose would be in the way. But if you were doing multiple small cuts on smaller pieces of timber it would be efficient in collecting the dust.
I suppose closing off the secondary collector would bring back the suction on the primary collector.
Let me call on our experienced members @JoeAzza, @TedBear and @Dave-1 for their observations on the new dust collection system.
Again, thank you for sharing your observations with the community.
Good Morning @dbaarda
You have made me think of picking up an Ozito table saw! 🙂 I was scrolling through all the information I could find plus watching some youtube links.
A couple of questions.
Do you need to use that T piece adaptor or can the hose be connected straight through?
aybe with teh T piece it is mean to have a cap over it when not needed and/or the ability to use for something that needs vacumming over a different area?
Next time I am at Bunnings (usually once or twice a week lol) I will have a look as now I am interested also.
The T piece is not removable, it's part of the single moulded part encasing the blade underneath. So yeah, you'd need to cap it with something if you are not using the hose to the blade guard. No cap came with it, but also the hose that did come with it is not even in the parts list in the manual.
Comparing this new model with older models I've seen in youtube videos; the legs seem a bit more sturdy now, but they removed a rear table extension. This is not the place for a review, but it's worth remembering it is a fraction of the price of the competition, so it's not going to be as solid or rugged. The main body is plastic and the table and legs are pressed sheet metal. The fence only attaches at the front, and the mitre gauge feels a little sloppy in it's slot. However, for me as a hobbyist it hits a price/performance sweet spot and it'll definitely be good enough for the stuff I want to do, and if I really hit limitations I can make after-market mods/add-ons like in the hundreds of youtube examples.
One limitation I've noticed is the blade guard and riving knife it attaches to mean you cannot do non-through-cuts/dado cuts. Even if you remove the guard, the riving knife sticks up too high, so you'd have to also remove it. The manual explicitly says "WARNING! THIS TOOL IS NOT INTENDED FORCHANNEL OR TRENCH CUTS." and you are never supposed to use it without the guard attached. Apparently in the UK it's illegal for a table saw to not have a guard fitted, so dado blades are illegal and table saws intentionally have a "short arbor" so they can't be fitted. I don't know if this saw has a short arbor, but it would not surprise me if it did. Although limiting, this makes sense. When I first turned it on and heard the roar I thought "OMG, what have I done, this thing could permanently cripple me", and promptly re-watched every table saw safety video I could find.
This limitation also means you cannot use it with a custom sled, since the riving knife gets in the way. I would definitely not use this without a riving knife, and intend on leaving the guard on forever. When/If i really have a genuine need for a non-through cut or want to make/use a custom sled, I'll look into making or purchasing a custom low-profile riving knife.
Afternoon @dbaarda
🙂 I love the "not review" lol It gives me a lot of things to look at when i check out table saws 🙂 Its pretty much the things Id want to know if I was purchasing one given in a proper review style.
As to the vacuum T piece, now it is puzzling me even more so. Think a trip to Bunnings may be in order 🙂
Thank you very much for adding in those extra observations about the table saw. I'm sure our members appreciate the extra information, and it will come in handy when purchasing a table saw.
When reading your reply I noticed the "What table saw do you recommend?" question in the "You might also like" section at the bottom;
https://www.workshop.bunnings.com.au/t5/Best-Advice/What-table-saw-do-you-recommend/ta-p/85910
It mentions "Out of left field is Evolution 255mm 1500W Multi-Purpose Table Saw." Searching for that I found this;
https://www.totaltools.com.au/147019-evolution-255mm-1500w-multimat-table-saw-w-stand-r255mtsThat looks a hell of a lot like a re-badged version of the ozito table saw. The body, stand, mitre guage, and fence look identical. Note the interesting extra vacuum hose going from the blade guard! The blade guard does look different though, because on the ozito it's clear... but... look at the third picture they have of it, and viola! it's the same clear blade guard, again with the hose attached.Its not exactly the same as the ozito package because they include a special multi-material blade and it must be narrower because I notice it has a narrower riving knife; they say 1.8mm, and on the ozito it's 2.2mm.
Morning @dbaarda
Any chance of a photo showing what's happening underneath your Ozito table saw - especially with that vacuum hose?
Cheers!
Sure! These show the underside and how the dust-collection port and T are all part of the single injection-molded plastic part that makes up the blade shroud;
wow... those photos are not rendering nicely in the post for me, but if you open them up you can see what they are.
@dbaarda
lol Yeah they dont look great but when I clicked on them they show nicely.
Thanks! @dbaarda
All makes sense now. I was trying to figure out how it could suction near the blade. The entire blade appears to be encased in a plastic shroud with a vacuum port. What happens if there is no vacuum - does sawdust build up in the cover or does it just spit it out that port?
My extractor/collector is a wooden box sitting under the blade area.
Long story, but the original stand had no 'floor' as such and dust was going everywhere so I used a steel plate with a perfectly cut hole in it which once belonged to a hospital pathology centrifuge.
Works OK - mind you I only use it out in the open.
Hi @dbaarda
"That looks a hell of a lot like a re-badged version of the ozito table saw."
I was thinking about this yesterday cleaning out my shed. It was very common in the late 1990s and early 2000s, in chain stores like Clints, Go-Lo, BigW and Kmart - but I would have thought this would not be the case now? But what would I know.
This is a classic example - both planers from the above period. Different badges, but the only difference is the coloured plastic.
There is a kind of "flap" on the side of the plastic shroud with a bit of a gap that is held almost closed by a screw with a big silver washer. You can see it in the second and third photo. I think that without a vacuum this flap hangs open enough for most dust to exit the shroud, but with a vacuum it gets sucked closed. I haven't actually observed it in action, but I do know that without the vacuum attached I end up with a lot of dust falling straight onto the floor.
An update on this. I looked into getting a similar multi-material blade for the Ozito and found there are a few other minor differences between these models that complicate things;
1. The motor is (probably different). The quoted power and speed is less for the Evolution (1500W, 3250rpm Evolution vs 2000W, 5000rpm Ozito).
2. The bore is different (25.4mm Evolution vs 30mm Ozito).
This makes it difficult to impossible to fit the same blade on the Ozito, both because the bore is the wrong size (there are claims specialist blade sharpening shops can re-bore a blade to a larger size but it's not recommended, and definitely not DIY), and because the blade specs say it has a max-rpm of 4500rpm.
In general there appears to be less blade options for a 30mm bore than for a 25.4mm bore, which is a pity. However, the Ozito has more grunt and a larger bore is probably necessary for that.
Thanks for sharing that extra information about the Ozito table saw and saw blades. I'm sure our members will find it very useful.
