Hi there, I’m looking for some help choosing the right door as there are so many options it can get confusing and overwhelming!
I am converting an area in my garage to an office which includes building a partition wall with a door in it. This door will seperate an area that is technically ’internal’ as it is not exposed to the weather however, it will be exposed to the extremes of heat and cold that garages typically get too. It is because of this that I think I will rule out the honeycomb core doors but I am also not keen on the expensive solid timber core doors so I believe I’m left with the hybrid ‘solicore’ doors that are chipboard internally.
I am after a 770 wide 2040 high door but I don’t understand the different finishes on the available doors and I would also like to buy the whole setup, pre hung including the jambs so I can install straight into my stud wall opening however I can’t seem to find the right information online to see if that’s possible to purchase?
do I need to buy these all separately and put them together and hang the door myself or is there a package solution for the above door that comes pre put-together with the jambs?
justin
