How to fix leaking in garage?
ChrisA
Building a Reputation
Hi everyone,
I have an old garage that I want to convert to a music room with lots of equipment. It has hardiplank on the outside and I plan to add acoustic insulation it and then add thick soundchek plasterboard for sound proofing.
My problem is that some water gets in at the bottom of the walls in heavy rain and I wanted to make sure this was fixed before starting work on the room.
On the advice for a local plumbing store I installed a down pipe and a stormwater pit which goes to a pit of blue metal…but this overflows in heavy rain. (please see pics)
My question is should I install some type of drain around the garage before doing the project and if so what type.
Also should I try to waterproof around the bottom of the walls?
As you should be able to see I. The fourth photo the fence is higher than the bottom the shed and the land slopes down.
I would be grateful for any help/ suggestions.
ChrisA
Re: Drainage issues
Ok thanks so much for the great advice.
Regards
Chris
ChrisA
Re: Drainage issues
Hi everyone,
I wanted to know how to connect flexible slotted agi pipe to the drainage pit pictured below and also how to connect a soild pvc pipe to the other side which will be going to the stormwater drain. Is there a connector I should use...or a glue?
Regards
Chris
Re: Drainage issues
Hi @ChrisA,
It sounds like you'd be looking for a Everhard EasyDRAIN Pit Boss Connector
Remember that in accordance with the Australian Plumbing Code, only licensed plumbers are authorised to undertake plumbing or drainage work. While homeowners can handle minor tasks like changing a tap washer, replacing a shower head or installing an irrigation system, drainage work would fall outside these areas.
ChrisA
Re: Drainage issues
Thanks Mitchell....I did see that but it looks like it will only work with 90 mm pipe ...the agi pipe is 65mm.
Re: Drainage issues
Sorry @ChrisA. I should have mentioned you'll also need the 100-65mm reducer.
ChrisA
Re: Drainage issues
Great thank you!
