Hi. I have just bought an Ozito 12v cordless drill. Could I use the battery from that in an Ozito 18v Circular saw or other Ozito power tool.
What’s the difference between the twin pack Ozito batteries for $89 and the one for $129. Both are 18V 4.0Ah so I’m not sure which to buy.
Hi @Derek3,
The Ozito PXC 18V 4.0Ah Compact Batteries are a new addition to the PXC range that is essentially the same as the Ozito PXC 18V 4.0Ah Battery Twin Pack PXTBP-240 in terms of run time, they just come in a compact format.
The $89 Ozito PXC 18V 4.0Ah Compact Battery PPBP-240 - Twin Pack is a limited-run promotional line that is fairly low in stock countrywide, so if there are any available around you, I would snap them up before they are gone.
My Ozitto grass trimmer of several years came with an 18v 1.5 AH battery . The current x-range 2 AH Battery does not fit .
Does this mean as i can no longer buy a battery to fit and that I am up for a total new grass trimmer with battery kit?
Hello @mark571
Can you please tell us the model number of your line trimmer. How many years have you had the line trimmer in your possession. Would it also be possible for you to post a photo of the product identification tag of both the battery and the line trimmer. We can try and double check for you if the battery is still available from Ozito.
Battery is OLBP_0185 Grass trimmer 3QY9XJR
Hello @mark571
Thanks for providing those numbers. If you can post some pictures of the line trimmer and battery as well, it would be very much appreciated.
Thanks Eric, I went to Bunnings today and noticed on sale for $99 I was able to buy a new grass trimer with battery and charger and ten blades. The new battery is now interchangeable with my other two Ozito Tools. So, it is not worth chasing up a compatible Battery for my old Grass Trimmer. Thank you for your replies.
Hello @mark571
It's good to hear that you've found a new Ozito set to trim your lawn. Plus, it's great to know that the grass trimmer battery is compatible with your tool set.
Please inform me where I can purchase Ozito battery adaptor, which enables use of Makita batteryin Ozito chainsaw
