How do I unscrew a wall mounted faucet?
fraser
This huge leaking faucet can't be unscrewed as it hits the window, and can't be unscrewed off the wall as it will hit the basin. What do I need to do here?
Noyade
Re: How do I unscrew a wall mounted faucet?
Good afternoon Fraser. @fraser
Could be my eyes - but there appears to be an allen key grub screw on the right.
Remove it (don't lose it).
The spout should now pull off in the vertical frame.
O-rings should be present and most likely worn - they will need to be replaced, assuming it's leaking from the swivel joint.
Welcome to the Bunnings Workshop community @fraser. It's wonderful to have you join us, and many thanks for your question about removing a tap spout.
As @Noyade has pointed out, this spout doesn't unscrew but is held together with a grub screw. Remove the screw and pull the spout straight upwards out of the lower fitting.
Please let me know if you have any questions and how you go.
Thanks Noyade and @MitchellMc - all sorted now!
Fantastic, thanks for letting us know @fraser. Feel free to post anytime you need a hand.
