Hi, Everyone
I need advise to select correct and cheapest material including steel furring, track, adhesive, screws and gyprock available at Bunnings to cover my existing brick wall in bedroom and living room, which I want to DIY cover with gyprock. please suggest the tools required as well.
Need advise on how to complete this project spending less but using good material.
Thanks
Direct stick if your wall is reasonably straight.
Hello @Lamsar,
Welcome to the Bunnings Workshop community. Thank you for joining us and sharing your question about gyprock.
It's great that you've received some advice from @Brad. The link he's provided actually has a shopping list of the materials you will need to attach your gyprock. This guide should help Installing Gyprock plasterboard - How to plan, prepare and measure up.
Another option for you would be to render or hard plaster the wall. I suggest this step-by-step guide: How to hard plaster a brick wall. Depending on your time and budget both options will work for your brick wall.
Let me tag experienced members @Adam_W and @Chaks_DIY for more recommendations.
We look forward to seeing your project begin, if you need more information please let us know.
Hi@Eric,
Please advise if I can get a steel frame to screw the gyprock instead of using adhesive and stick to the wall.please mention the recommended frame material I can buy from Bunnings.
Thanks
Hi @Lamsar,
@EricL will be able to assist further when he's back on the site on Friday. Did you find the guides he shared helpful for your project?
Let me also tag @tom_builds to see if he can offer any suggestions. Thanks for your patience in the meantime.
Stevie
That is the lowest profile for a non load bearing wall, you will need a top and bottom track fixed into place and steel studs are friction fitted into the track.
Hello @Lamsar
It's great that you've received fantastic advice from @Brad. Using the Knauf Steel Wall Stud is the ideal product to use if you don't wish to bother with glue and timber. Knauf light gauge steel studs are used in conjunction with a steel track to provide a framework for internal, non-load bearing wall structures. The track is secured as a top and bottom plate and studs are spaced evenly between.
Here is a handy guide to help you with installation:
I recommend measuring your wall, for you to estimate the number of pieces you will need to complete your project. We would love to see your project once you begin. I'm sure our members would appreciate any updates you can provide.
