How to install portable AC vent in casement window?
ageorge
Hi, I live in a rental house and have a tilting casement window in my bedroom. Unfortunately, it’s the only window available.
The casement window tilts open from the bottom and has a fly screen attached.
My question is: how can I install a portable AC vent in this space?
Re: How to install portable AC vent in casement window?
Hi @Noyade 👋
Whilst I've never used a collapsible hand trolley (I have an old steel P handle trolley) the application of ratchet straps to secure the load will have the added bonus of increasing overall rigidity 👍
@MitchellMc is spot on, make the most with what you already have given it is rated @250kg 😉
Noyade
Thanks! 😁
Ever taken something back to the Bunnings returns desk and hesitated - thinking they may not believe your story?
The response today, when I demonstrated the issue, was ...
"Wow!"
"Have you got the card you used?"
It's the initial lift that is the issue.
Keep doing this and you will eventually fracture the plastic at the rivet point.
Noyade
Sorted out the trolley/transport issue.
Now working on Prototype No.3.
Around 10 kg - thanks to 12 mm steel plate at the base.
Stability with the drooping hose - is amazingly rigid.
I'm hopeful.
