I would appreciate some advice on the best solution for an internal door that no longer closes properly.
I have checked and the door is still attached firmly by the hinges, so I can only think the weather of late has expanded the wood at the top of the door, as there are visible rub marks at the top of the door, in the centre area. It appears to be only a few mm's out.
My first thought is, to use a plainer to take a few mm's off the top of the door, or alternatively should I try tyo adjust the hinges to free up some room?
Thanks in advance for any suggestions
