Would like to enclose alfresco with a wall to put tv on - can I frame bottom to the decking or should I remove decking and bolt to existing concrete slab?
Welcome to the Bunnings Workshop community @Michelekranzy. It's wonderful to have you join us, and many thanks for your question about creating a stud wall.
You could likely build the wall on the deck if there is an adequate amount of footers and joists to support the weight of the wall. If you can fix the wall frame to the house bricks and pillar, that would help bear a portion of the weight. It would be best to have the wall start at the ground, but as long as the deck is adequately reinforced, it shouldn't be an issue.
Here's a handy guide on How to build a stud wall. For your wall, you'll need to use materials suitable for external use, like H3-treated framing. Remember your PPE when constructing the wall, including a face mask, safety glass and gloves.
Thanks Mitchell
yep beam directly under where we are putting base plate
also just a partition as self supporting area - thanks for your import so much appreciated- feel heaps better now so grateful
I thought I'd also link this project @Michelekranzy. @Baggs added an Alfresco wall for privacy and weather protection. It wasn't on a deck, but it's a similar project and likely worth a look.
Keep us updated, and reach out again if you have further questions. I can't wait to see your results!
Thanks Mitchelll
saw this post - great read
