How to loosen pool glass stuck in spigot?
ADV
Hi, I need to lift a panel up about a cm.  The screws are loose but the glass is stuck to the rubber/plastic packer.  Any ideas on how to remove/loosen it etc.  Thanks
Re: pool glass stuck in spigot
That's a bummer, @ADV. Have you tried early on in the morning when the rubber hasn't been heated by the sun and become sticky?
ADV
Nope, good idea, will have a go in the morning.
JoeAzza
Kind of a Big Deal
Re: How to loosen pool glass stuck in spigot?
Hi @ADV ,
@EricL idea using WD40 is good, just to add to this, try running a fishing line between the glass panel and the rubber support, this should free up the seal between the glass and rubber, this will also tell you if there is another obstruction as suggested by @MitchellMc
ADV
Thanks mate
Love the fishing line idea @JoeAzza! Dental floss will work in a pinch, too.
If you haven't removed car badges with fishing line before @ADV, the process works best if you keep the line taught and use a sawing action.
ADV
No luck yet.  Tried the fishing line and it catches at the height of the first screw, almost as if there's something in there.  I pushed a sharp thin knife down the spigot and it hit the same thing at the same height.
Hi @ADV
I suggest getting an extra pair of hands to hold the glass up from the bottom while trying to do the fishing line technique. I suspect that the spot you're hitting is the holding point of the glass. It might be necessary to relieve the pressure being exerted on it by having an extra pair of hands. I propose doing a combination of the WD40 and fishing line to make the line pass through easily between the spigot and the glass panel.
If you need further assistance, please let us know,
TedBear
Kind of a Big Deal
I suggest checking for the possibility of a protective sleeve running through the spigot and the glass.
If so, you'll need to make or find a wooden punch at the right diameter to push it out.
