Hi Team,
I am Ashriya and you might already know from my previous posts - making a seedling planting system. I have came up with another idea.
uhm imagine a metal rod, holding the entire cylinder drum bit like a pendulum but rather steady in terms of horizontal motion but goes down and up to its original spot. the cylinder bit will rotate as its got a 6 drums for now, which have a drill attached to the end of it, and has a seedling inside the drum and has a small lid opener right underneath it, so it uses some kind of sensors to when the metal rod pushes the cylinder bit to go down and drill into the soil and come back up, using sensors it will open the lid for the seedling to fall through and it rotates after that.
Is there any advice on what kind of materials and how I can get started on this project?
Few questions I am also currently considering for this system is
1. how will the seedlings be watered?
2. how will the seedling fall straight down once the lid is open?(as there is no pvc pipe for the seedling to fall through)
3. how can i make this system automatic?
Your help would be greatly appreciated!!!
Thank you
