Good Morning
Iam in the prep stages of building my very own decking in my new home just recently build.Iam considering a steel frame to use and wondering how to get one ready made for a 3.6m by 3.8m ?
Also its a ground level based,The area is mostly hard surface rocks.am also considering to use very low concrete and post to hold the decking but not sure if that a good idea or just lay it on the ground.
Welcome to the Bunnings Workshop community. We're pleased to have you join us and look forward to reading more about your decking project and other plans for around the house and garden. We're sure you will get plenty of helpful information, advice and inspiration from our amazing community members.
Normally I would ask the ever-helpful @MitchellMc to assist you, but he is taking a well-earned break at the moment. Let me tag some other helpful members in @Brad, @TedBear and @Adam_W to see if they can share their thoughts. I would also recommend you take a look at Adam's comprehensive guide How to build a low-level deck.
Thanks for your patience,
I have used a steel flooring kit for a shed floor using decking.
Bunnings do have a custom order service for steel decking frames.
Hi @Kana I can recommend the Steel Deck product highly.
I first used it for a pool deck and have since used it for our entire renovation!
Found it super easy to use once you get your head around the assembly basics & their team are very helpful.
For custom sizes you can just give them plans & they come back with full specs & pricing and you can also get an engineering certificate from them if needed.
Hi @Kana,
It's great to see you've received helpful replies from @Brad and @Adam_W.
You can place your frame directly on the rock surface. However, you might find that it is uneven, and in this case, you must level it out on either concrete pads, packers or posts.
Please let me know if you need further information on our Steel-Deck product range. If you see our Special Orders team at your local store with your sizes, they'll be able to arrange a quote for you from the manufacturer.
