I have the roller blockout blinds, when there is the slightest wind they bang non stop, would love a simple tip to stop this.Thank you.Leonie
Hello @Leonie_D I am not sure of whether you are speaking about indoor or outdoor blinds, could you link a similar product or picture for reference please? 😉
A warm welcome to the Bunnings Workshop community, @Leonie_D. We're delighted to have you join us.
Thanks for your question. I agree with @DIYGnome that it would be helpful if you could provide more details of your blinds as well as photos of the blinds and the area where they have been installed. This will enable our resident Bunnings D.I.Y. expert @EricL and other members to provide more tailored and specific advice.
Let me know if you need assistance in uploading photos or if you have any questions navigating the site. Happy to help.
Akanksha
Hello @Leonie_D
There are solutions to keep your block out blind from banging into your window frame even in windy conditions. But in order for us to give you a comprehensive solution, would it be possible for you to post a photo of your block out blind extended and a picture of the window frame as well.
In these situations, I often suggest using Zenith 8mm Black Shock Cord Button - 8 Pack in combination with Zenith 90mm Black Stretch Loop - 2 Pack. This is on the condition that there are mounting spots for the button and the loop.
However, if there no mounting points it will be necessary to provide a different type of anchoring solution.
We look forward to seeing the photos.
Hi EricL,
I have honeycomb/paper like blinds. Will the shock cord button and stretch loop combination work with these blinds. If not, would love to hear an alternative solution. Thank you
Welcome to the Bunnings Workshop community @happycat. It's terrific to have you join us, and many thanks for your question about blinds.Let me tag @EricL to see if he can answer your question.
Are the blinds fitted within the window frame, and do you typically have them extended right to the lower frame when in use? If so, you could potentially attach stick on Velcro on the bottom edge of the blind and the window sill. You'd simply pull the blind down and attach the Velcro to keep it from moving around. Even if the blinds are on the outside of the frame, a similar fix could be suitable.Please let me know if you have any questions.Mitchell
Hi Mitchell,
The blinds are fitted within the window frame. The blinds only move around when the windows are open, making a knocking sound. I’m try to find a solution which allows me to pull the blinds up and down.
Hello @happycat
Thanks for that extra information about your blinds. Now that I see what you have installed, I suggest going with MitchellMc's recommendation. I propose using the VELCRO Brand 25mm x 1m White Stick On Hook and Loop Tape. This is easy to install and will keep the bottom of the blind from moving.
Thanks Eric and Mitchell.
I can’t visualise how to install this on the blinds. Could you please provide a bit more info? Thanks
Hi @happycat and @Leonie_D
I had the same issue with my blinds so I have stuck some self adhesive felt strips on the bottom inner edge of the blind where it bangs against the window winders (in my case) on the frame. This has turned a "thud" into a barely perceptible bump that doesn't disturb me at all. If you don't have winders you'll probably only need a little at each end, since the middle can't then hit anything.
This is the type of felt I used but it comes in other sizes and colours...
https://www.bunnings.com.au/surface-gard-13-x-1473mm-beige-adhesive-felt-strip_p0262187
Maybe that will work for you too.
The Velcro strips are composed of two parts the hooks and the pads. They have stick on adhesive behind them so you can place one side on the bottom of the window frame and the other at the bottom of the blind. When you pull the blind down, they will stick together and when you pull them up, you'll need to give a small assist with your finger at the bottom as the Velcro sometimes sticks very well together.
Please note that putting too much Velcro will make it very difficult to lift the blind up. I therefore suggest starting with a short strip at the sides and adding more if you want it to be firm.
Hi,I have a similar problem where my blackout roller blind was mounted on the wall and in the game of the window recess as the recess was not deep enough. The blackout blind is on the window side and my sun filter bling in on the bedroom side.
How can I stop the the my blinds from be blow into the window recess are when the air-conditioner is on?Thank you in advance
Hi @TwoLeftHands,
Welcome to the Bunnings Workshop community. We're pleased to have you join us and trust you'll get loads of help and inspiration for all your projects around the house and garden from our wonderful members.
Do you think that Eric's suggestions earlier in this discussion would work for you?
If not, could you please post some photos of your extended blind as well as the window frame so we can see what you are working with and suggest alternative approaches.
Thanks,
I have found these work great. https://www.amazon.com.au/BlindMuffs-Blind-Guides-Blinds-Banging/dp/B0DB76X7V4/ They just clip on the bottom and can either sit in the track and move up and down with the window, or be clipped to the rail itself so they won't move even in the strongest winds!
Hi @Kuzon,
Thank you for sharing.
