Axon cladding, aluminium trim, waterproof sealant, and a lick of paint created a splashback that is easy to clean.
The project
We used James Hardie Axon cladding to create a vertical panelled-look splashback to complement the shaker style cabinetry.
We wrapped the cladding around the walls of the kitchen and capped the end panel using white aluminium tile trim. The cladding required around five coats of Taubmans Professional white gloss water-based enamel paint.
We painted the panelled grooves and edges with a brush and used a foam roller to roll on the enamel paint. The foam roller helps to create a smoother finish and avoids leaving any brush stroke marks.
We then siliconed all the edges that meet the top cabinets and benchtop using Selleys wet area waterproof silicone sealant. Maintenance and upkeep is minimal. All we do is wipe up any oil or sauce splatters straight after cooking with a wet sponge (water or Ajax Spray and Wipe). Due to the glossy surface, everything wipes straight off with just one swipe.
How to tile a splashback
Whether you just want to give your kitchen a quick facelift or are renovating an investment property, one of the simplest methods is to replace your splashback. Workshop member Pete has shared How to tile a splashback for a step-by-step guide.
More inspiration for your kitchen project
Workshop member Trish completed a splashback refresh with paint and created a modern, elegant kitchen.
In his cosmetic kitchen makeover, Rufaro painted over a tiled splashback.
Get more inspiration from Workshop members with 7 clever kitchen and laundry splashbacks and our Top 10 most popular kitchen projects.
