I want to make my new garden shed floor as watertight as possible. My other garden shed was installed on concrete pavers 3cm thick, but water keeps seeping into the shed inside wetting things in there. It was professionally installed and I believe they bolted it down and then sealed it around the inside edges in places with a regular sealant, but it doesn't appear to have been enough to keep the water out which is very frustrating and literally a waste of my money.
So I would like some advice on my second shed floor. I can't have a concrete slab so that really only leaves concrete pavers again. I am wondering if it would be okay to lay the concrete pavers then put a steel frame over them and then some sort of floor over the steel frame so that the shed is raised off the ground. What does anyone think of that method?
The person who is going to install the shed said it was overkill and all it needed was to lay the concrete pavers and then seal them with pavelock to make them watertight, and then once the shed is installed then put a sealant around the edges inside. I'm not sure about this method as I have no experience with pavelock, but as someone who is anti pesticide and anti chemical I am worried that it's very toxic and the poisons could leach out eventually which could be inhaled by anyone near the shed.
Thank you for any advice.
