Hi!
TL:DR I want to get rid of the metal tubes. What are they? Can I get rid of them? How?
There are six of these metal tubes about evenly spaced on one wall of the kitchen (rendered brick that backs onto the loungeroom and a bedroom). I had originally thought they were wooden dowls or something. Some people have suggested they may have been used for decoration or preparation for shelving. I have had several tradies over for other jobs and quotes and so far, but none of them have been able to identify what they are. To my knowledge, there shouldn't be any plumbing or electrical going through there since they are far from the nearest sink and the power points and light switches and I can't think of anything else they could be for.
The other day, going under the assumption that they were just wood, I tried to remove one (the one that stops abruptly above the loungeroom door frame). The lower part easily separated from the wall with a chisel and didn't cause any problems. I then tried to chip off a little bit since the material itself was harder than I had anticipated and I wanted a closer look. That's when I scrapped of some of the (many layers of) paint to find blackened metal underneath. Then I got a magnet and stuck it to each of them (I don't know why I didn’t think to do it earlier) - they are all magnetic.
I had a look online to see what they could possibly be made of and for, but came up empty. My best guess is that they are cast iron (given the tarnish is black and powdery), but again I cannot figure out what their purpose could be. Two of them end very abruptly and the others seem to lead into the wall. Does anyone have any ideas? One source claims they might be weep holes, but I don't think that's the case since, as opposed to weep holes, they are fully enclosed (no openings on the ends) and the wall is an internal rendered brick wall - not an external cavity wall.
I would like to eventually have some overhead storage put in (there is currently very little storage in the kitchen), so it probably isn't that big of a deal for the three above the kitchen bench if I go with open backed cupboards, but I would like to remove the other three at some point to put shelves up. Does anyone have any suggestions on what to do?
Thank you
Tubes on kitchen wall above the door to the lounge room
Tubes on kitchen wall backing onto bedroom
Close up of the one above the door 2 of 3
Close up of the one above the door 3 of 3
Close up of the one above the door 1 of 3
Tube to the immediate left of the door (leading into wall?)
