I am in Elizabeth, SA. I have a 3 year old, 6m x 9m Colorbond (steel frame) shed with sliding doors, which gets so hot it's impossible to work in for more than a few minutes. Last year vents front and back were put in, which help a little but not enough. I had thought of installing whirlybirds, but unfortunately there is a Eucalypt hanging over part of the roof which sheds masses of bits which would not only quickly stuff up the whirlybirds but the bits would be blown into the shed - this was already happening along the roof ridge so closed cell infoam has been put in which has been excellent. Very windy where I am.
I would like to insulate the shed and start with the doors, but don't know which option would be best. I've seen
- GI Building Sciences 10mm 0.5 x 24m 12m² Reflecta Garage Door Insulation;
- Ametalin 1500mm x 20m ThermalLiner Roof And Wall Shed Insulation; and
- Foilboard Green 10 x 2400 x 1200mm Insulation Panel
and then there are batts, but that seems like a huge job and may be unnecessary, I hope? I would also need tape and/or sealant which would tolerate the heat.
I don't want complete cool, necessarily, but enough of a lower temp so that I can work in it without running outside to recover! I've watched some videos, but none of them seem really relevant to what I need.
Any advice would be greatly appreciated.
Thanks very much
SuJay
