Hi all,
would love some advice and recommendations.
I’ve recently purchased a weatherboard house and one of the room constantly have this damp smell when we don’t air the room, I think it is because water is coming in from the outside.
outside of the house, as you can see from the picture, the original owner had brick paving right up against the base board. As you can see in the photos, the board has already started to rot as it is mostly under the brick and sand. Because of how the backyard is laid out, I cannot lower the brick pavers without significant work.
I’m keen to get advice on how to fix this. I was thinking of replacing the base board with fibre cement, but cannot find anything similar in style, so was thinking of keeping the base board, spray some wood hardener, tape the plastic over the slab with the timber with g tape then paint over with several layers of bitumen rubber.
I was also thinking of putting some French drains along the edge of the house to drain out any excess water. Only issue is I’ll struggle with fall and might just be level.
thoughts? Any recommendations?
thanks
Jack
