We have a cavity sliding door for our powder room. lately it’s been hard to open and close. i checked and the door is not centered and is touching the inner side.
I already removed the centering guide on the bottom side but it’s still not centered. As you can see in the photos there’s scratching on the inner side of the door.
How do I go about to fix this problem? the access to adjust the bolts holding the door is very tight as well. tried it with a spanner and cant get a good grip.
thank you for your help.
Inner side of the door showing scratching on the upper part. Also, notice there’s not much clearance/gap between the door and the cavity wall on this side.
Next photo is from outside part of the door. large gap between door and cavity.
This is how it’s mounted:
