Hi there, I'm putting up a 17m wide, 1.8m high picket front fence with flat top cypress pickets that are spaced 19mm apart, and am looking for tips about the painting process. I'm probably not going to spray it..
- A friend recommended to stack the pickets on their side and roll the sides of the pickets first before installing. I'm not sure how I go about that efficiently so that they don't stick together as they dry, or run over the front. I live in a very rainy part of coastal Victoria, so finding long sunny days is tricky at the moment.
- If I install the pickets first, then paint them, is there a roller that can paint the sides if the spacing is 19mm?
- Another thing here is I'll only be able to peck away at the job on weekend days that are sunny. Is it ok to install cypress pickets, have them exposed to weather for a couple of weeks before ideal painting conditions happen?
Thanks in advance!
