Hi everyone,
I’m planning to add insulation to my existing Colorbond garage shed, but I’m still unsure about the best approach and would really appreciate some advice from people who have done similar projects.
Roof insulation
My current idea is:
- Install timber battens along the roof purlins first to create an air gap
- Then install Foilboard onto the battens instead of attaching it directly to the metal roof sheets
From what I’ve read, this air gap should help improve the insulation performance and possibly reduce radiant heat transfer.
Would this also help prevent condensation issues, or is there a better approach for a metal shed roof?
Wall insulation
For the walls, I’ve seen people recommend either:
- Corflute panels: https://www.bunnings.com.au/3mm-corflute-white-900-x-600mm_p0390160?region_id=118196&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB-cJ-1CkzzDnypSmMoOUvd-h&gclid=Cj0KCQjww8rQBhDjARIsAE43KPMLAfbNJl0aKKB7qTDbBXJxSGlH7iGfQ9kQ_7rppLIqQkFfCifsHMsaAmnwEALw_wcB
or - A vapour barrier / builder’s plastic: https://www.bunnings.com.au/ametalin-1370mm-x-30m-vapourtech-brane-vhp-vapour-permeable-wall-insulation_p0811065?store=8196&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB-cJ-1CkzzDnypSmMoOUvd-h&gclid=Cj0KCQjww8rQBhDjARIsAE43KPPMv7bqlQ4NVk2cqNlgSjqrw_GnHZl-7LM-lozDeli-f-a-LuAB5LUaAvF_EALw_wcB
But I’m not completely sure how these should be installed.
My current understanding is something like:
Metal wall cladding
Corflute or vapour barrier
Glasswool batts
Plywood or plasterboard lining
My questions are:
- Should the Corflute or vapour barrier be installed directly against the metal wall, or should there also be an air gap between them and the metal cladding?
- Is Corflute mainly being used as a moisture barrier to stop condensation from reaching the glasswool?
- Should the glasswool directly against the Corflute or vapour? or should there also be an air gap between the glasswool and vapour?
- Would plywood be a better option than plasterboard for a workshop/garage environment?
Sealing gaps
I’ve also used expanding foam to seal the gaps between the roof and wall sheets (both the top and bottom part) to help stop insects and dust entering the shed.
Was this a good idea?
I’m now wondering whether sealing those gaps too much could reduce ventilation and potentially increase condensation issues inside the shed.
About the shed
- Existing Colorbond steel shed
- Steel frame construction
- Located in Brisbane
- Mainly used as a garage and workshop
- Priority is reducing summer heat while avoiding long-term condensation or mould problems
Any advice, recommended wall/roof build-ups, or lessons learned from your own shed insulation projects would be greatly appreciated.
Thanks in advance.
