My living room curtain rail has come undone (courtesy of little humans), as a result the hole in the wall has also enlarged causing the plug (Ramset 7 x 35mm Green Wall Plugs - 25 Pack - Bunnings Australia) to be unstable and therefore the rail/bracket is unable to be screwed close against the wall.
Any recommendations for repairing - is it worth trying a bigger plug (like Ramset 8 x 50mm Blue Wall Plugs Blue - 25 Pack - Bunnings Australia)? Or will a gap filler be required for the existing hole? This is double bricked wall and I imagine if I am to drill a new hole it may need to be a bit lower than origin? to remain in alignment?
As an alternative option, I was thinking maybe drilling an additional bracket on the upper side of the existing screw?
Any suggestions for products and advice would be appreciated thanks!
Joey
