My shed is leaking I think partially at least because the ground slopes towards one corner. It's then creeping under the shed door. I'm not sure if it's also because the metal wall panel next to the door isn't sealed properly where it joins the acrylic siding?
My main question is how do I fix this? Do I need to install some kind of drain or can I add concrete to make the ground less sloped into the shed? My fear is a shallow layer of concrete will simply break off, but the shed is fairly surrounded by building so installing a drain would be a mammoth task and ideally not necessary if i can just direct the water away from the building.
thanks so much!
