Hello,
We have a glass sliding door as pictured where each panel is about 1m wide. There are three blinds corresponding to each panel, however the middle one has come loose. Now the one on the right is also falling off, as the short screws it was installed with cannot hold its weight.
- We have tried to put in longer screws, but discovered the ceiling panel is hollow and only about 3cm thick. So this didn't work.
- We have some toggle anchor screws, but the screw holes are too close together (about 1cm) to accommodate the larger holes they would require.
Any advice on what to do would be appreciated. We are open to any other suggestions to replace the current blinds with something else or changing how it is mounted somehow. The only solution that wouldn't work for us is standard curtains that pull to each side as it would block off the part of the window next to the desk.
Thank you!
