I want to make a 2 metre six inch pvc fishing rod holder to place on my roof rack of my 4WD. It must have screw on ends at each end and have some sort of U mechanism to attach it to the roof rack.
Hello @NeillHodgen
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about 6" PVC piping.
The equivalent of 6" is around 152.4mm, the pipe the store carries is 150mm which is very close. Below are the parts I suggest in order to create your fishing rod holder.
The threaded access coupling can be glued onto the pipe itself, and the front has a threaded fitting which the threaded access cap can fit on. The other end can be covered with a standard push on cap which also needs to be glued on. But if you wish to have end to end access you can install threaded fittings on both ends.
To anchor the pipe to your vehicle, I suggest looking at using the Airco galvanized strapping. Please note that your car should have a form of roof racking already attached. In the interest of health and safety, I suggest using a galvanized nut and bolt configuration to hold the strap in place. However, should you find a 150mm "U" pipe clamp that would be ideal as well.
Yes, you can use a galvanized nut and bolt on an aluminium pipe, but you must prevent direct metal-to-metal contact to avoid galvanic corrosion. Use a non-conductive barrier like a nylon washer, rubber sleeve to physically separate the steel from the aluminium.
Please remember to wear personal protection such as gloves and goggles.
Let me call on our experienced members @Dave-1, @Noyade, @TedBear and @MikeTNZ for their recommendations.
Hi @NeillHodgen
If your rods are valuable, you may want the special orders team to get these for you,
Lockable end caps
They aren't cheap though.
Good Evening @NeillHodgen
I really cant add more than what @EricL and @R4addZ have suggested.
Good luck fishing :)
Purchased from a recent garage sale. Four inch PVC. I intend storing steel rod in them - hopefully preventing rust. Both ends shown with the main cap which looks water-tight with an O-ring.
Cheers!
As always I did not read the question thoroughly.
"U mechanism to attach it to the roof rack."
Can you still get those galvanised stepped brackets with nuts/washers and bent bolts for pipe? Something like this from memory?
Or make something similar.
Hi @NeillHodgen,
The typical approach for connecting pipes to surfaces is to use saddle clips like this https://www.bunnings.com.au/kinetic-150mm-head-pipe-saddle-clips-2-pack_p4920108 . I imagine there will be a way to bolt it to your roof racks to hold it in place.
@Noyade that looks like these https://www.bunnings.com.au/antsig-antenna-mount-u-bolt_p4361347 , but unfortunately, they are too small for the 150mm pipe. It would be a good option, but unfortunately, I couldn't find anything large enough.
hi @NeillHodgen
Saddle clips are available out there, speak to the special orders people at bunnings. You can show them this…..
150mm Saddle clips
Thanks for asking this question, while Bunnings may not sell this, a lot of Electrical suppliers do, this item is called a conduit tube and
it has threaded ends and caps, they would also sell the mountings to attach this to your vehicle, depending on the model of your roof racks,
please bear in mind that these will be expensive, they are made for Tradies.
EricL, gave you a list of fiitings that could make something like this, however if you only have a rod or two, you should look at a 100mm system,
these are more common and if you nest your rods with the rods together, the eyelets won't catch on each other.
If I can be of more help to you, by all means let me know.
Cheers,
Mike T.
